Michael_107360's avatar
Aug 26, 2018
NFS requests from privileged port (< 1024) issues with port-reuse
I have a forwarding virtual server configured with the recommended settings except for increasing the idle timeout due to NFS mounts. The timeout is set to 3600 seconds.
fastl4 profile:
idle-timeout 3600
loose-close enabled
loose-initialization enabled
reset-on-timeout disabled
Problem we are seeing in due to NFS port-reuse below 1024. If for any reason there is a network error or the Client Servers loose connection with the NAS filer the sympton is the Client waits 5 minutes then sends a SYN. This SYN uses the same source IP and the same source Port as the original connection. The F5 seeing a SYN coming from a device with the SAME IP and the SAME Source Port will DROP the packet. Until the connection is cleared the systems can no longer communicate. The Client keeps sending the SYN ever 10 seconds which resets the idle timeout so the connection will never drop. The only solution is to re-initialize the Client which then will send the SYN on a different Source Port. This does not happen if the Client uses port above 1024 but that is a security risk due to a non-root user gaining access.
Someone mentioned using TCP Keep-Alives? We have not tried this but any thoughts? If i do clear the connection in the connection table the request immediately goes thru and once again a connection is established.
  • Based on this article, in older versions, you could use the tcp keepalive to detect a dead connection. It sounds like after three keepalive failures, the BIG-IP will a)reset the connection and b) clear the connection table. I'm not sure if this still holds, you would probably want to do some testing.
  • Hello,
    I know this is an old post but I am facing this issue now.
    Could you fix this?
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      Did you do what was suggested before?
      Can you post the virtual server and TCP profile settings?
      • pponte's avatar
        pponte
        Hello,
        I did not apply keepalive to this profile because I was reading about how it works and it seems it sends a tcp connection to client and server.
        Both are alive so they will answer correctly, but if you think this could work I have no problem to apply it.
        The problem seems to trigger when we have a routing issue. Client loses connection to VIP and when it recovers and tries to reuse that connection F5 is not sending packets to the servers.
        Client keep sending SYN packets and renewing timeout so never clears connection table.
        Deleting connection solves the issue.
        This is VS and L4 profile configuration:
        show running-config ltm virtual SYNC_NFS_PRE_GCP_JC
        ltm virtual SYNC_NFS_PRE_GCP_JC {
        description "VIP_ SYNC_NFS_PRE_GCP_JC"
        destination 10.158.19.36:any
        mask 255.255.255.255
        persist {
        source_addr {
        default yes
        pool POOL_SYNC_NFS_PRE_GCP_JC
        profiles {
        fastL4 { }
        source 0.0.0.0/0
        source-address-translation {
        pool POOL_SNAT_NFS_JC_PRE
        type snat
        translate-address enabled
        translate-port enabled
        vs-index 225
        show running-config ltm pool POOL_SYNC_NFS_PRE_GCP_JC
        ltm pool POOL_SYNC_NFS_PRE_GCP_JC {
        members {
        NFS_NAS_PRE_Minsait_GCP:any {
        address 10.64.201.145
        session monitor-enabled
        state up
        monitor gateway_icmp
        show running-config ltm profile fastl4 fastL4
        ltm profile fastl4 fastL4 {
        app-service none
        idle-timeout 300
        mss-override 0
        pva-acceleration full
        reassemble-fragments disabled
        reset-on-timeout enabled
    • Haven't encountered this exactly, perhaps action on service down can help here, give reject or drop ago. I assume the BIG-IP also see the pool member as down for a while?
      https://my.f5.com/manage/s/article/K15095
      Else perhaps a lower idle-timeout on the L4 profile, create a different one and see how that goes.
