DHumber_151115's avatar
DHumber_151115
Sep 14, 2018
New Interface not appearing for vCMP Guest
I have a 5250v with a vCMP LTM guest on board with a configured VLAN/Trunk/interface. I want to add another physical interface and expose it to the guest LTM. I've created a new VLAN and trunk, and assiged it to the new int on the host. Then assigned it to the guest. The guest sees the VLAN and trunk, but there is no virtual interface appearing on the guest (e.g. 0.8). What am I missing?
Hosts and guests using 12.1.3 build 0.0.378
    • DHumber_151115's avatar
      DHumber_151115
      The first image is the results from the vCMP host int 1.2 is the interface that is not showing on the guest. This is result from the guest. 0.7 is int 1.1 and 0.8 is int 1.4
      Thanks,
  • I've gone so far as to spin up a separate vCMP guest and it still does not see the new interface. Anyone?
