Lazar_92526
Apr 05, 2013Network Solution verse Verisign option for CSR
All,
Easy quick question. When we order SSL certificates from Verisign in the past for our F5, we used to just select F5 from their otions for the CSR.
Network Solutions does not offer the same. Do we select Rehat Linux?
- Kevin_Stewart
Employee
I'm not sure that it matters. Verisign may have a template to add specific X509 attributes when signing the certificate request, but ultimately all you really care about is the signed certificate. - Lazar_92526
Network Solutions requires a choice, should I go with Redhat Linux?
- Kevin_Stewart
Employee
That should be fine.
