Netscaler to F5 Content switch iRule conversion
Netscaler to F5 iRule conversion,
Can someone assist with this iRule conversion.
Policy1: HTTP.REQ.URL.SET_TEXT_MODE(IGNORECASE).CONTAINS("/poc") directs to server 10.5.80.29 Policy2: HTTP.REQ.URL.SET_TEXT_MODE(IGNORECASE).CONTAINS("/mst") || HTTP.REQ.URL.SET_TEXT_MODE(IGNORECASE).CONTAINS("/mdrval") directs to server 10.5.80.31 Policy3: HTTP.REQ.URL.SET_TEXT_MODE(IGNORECASE).CONTAINS("/tst" directs to server 10.5.80.30 Policy4: HTTP.REQ.URL.SET_TEXT_MODE(IGNORECASE).CONTAINS("/sup") directs to server 10.161.96.89
- Vijay_E
Cirrus
You can use multiple if-statements within HTTP_REQUEST event:
if { ([HTTP::uri] contains "/poc") } { pool HTTP_pool member 10.5.80.29 80 } elseif { ([HTTP::uri] contains "/tst") } { pool HTTP_pool member 10.5.80.30 80You can also use an data group with URI:=Pool-Name. Each pool name is unique and contains the relevant members and then use something like:
when HTTP_REQUEST { set POOL [class match -value [HTTP::uri] contains CLASS_URI_POOL] pool $POOL } - Reginald_Sible1
Thank you very much that worked like a charm..
