swarup_368033's avatar
swarup_368033
Oct 20, 2018
need urgent help on f5 ltm Lb traffic.
I have 2 F5 in which, in Lb1 the traffic to port 16789 is ok, but in Lb2. the traffic to 16789 is not showing ok, where as both Lbs are in sync mode.
Lb VIP: 10.243.1.4 port 16789 Internal IP Lb1: 10.243.1.23 Internal Ip Lb2: 10.243.1.24
Server1 IP: 10.243.1.5 Server2 ip: 10.243.1.6
In Lb1 end tcp dump, i check towards VIP (PSH,ACK )
why in Lb2 its sending SYN... Need urgent help
  • Is it client traffic or monitoring traffic which is wrong?
    It seems to be client traffic through f5 as both connections are from same IP address..
    If it’s monitoring traffic, this is a duplicate ip issue.
