Need to know any possible way to clear cache/flush dns for a records on GTM/DNS where GTM act as forwarder for the query.
RX/vendor supplier changed the DNS records recently,We have situation where the TTL of DNS record expires in 86400 sec. BIGIP GTM is acting as forwarder for those records. When we clear cache on the forwarded DNS server , on BIGIP we are unable to see the change until TTL expires. So we need to know whether any way we can flush the DNS when the DNS queries is been forwarding to other DNS server.
ON GTM configured forwarder. zone "." { type forward; forwarders { x.x.x.x; }
- Samir_Jha_52506
Noctilucent
Option is there on F5 GTM but haven't use any more. Please find below link
https://support.f5.com/kb/en-us/products/big-ip_gtm/manuals/product/gtm-implementations-11-2-0/12.html
Hope article will be helpful.
- John_Heyer_1508
Is the forwarder setup in Zones -> ZoneRunner -> Zone List? If so, it's using the BIND/NAMED backend. This TMSH command will restart it and thus drop all cached records:
restart /sys service namedYou can also have the forwarder not cache at all by using the "forward only" option. Example:
zone "whatever.com." { type forward; forward only; forwarders { 192.168.1.1; 192.168.2.2; }; };However, you probably wouldn't want to apply this to "." since that would disable caching for general queries.
Bottom line - whoever is controlling that records should consider lowering the TTL. 86400 seconds is 1 day, and most people are using 1 hour or even 1 minute.
