Need suggestion on and operation
HI All,
I am looking to achieve for below url if webservices string comes in http::uri & end with .asmx keyword then virtual server will send the traffic to pool otherwise it will redirect to https. But it is not working as expected...
Below is the url :
http://powerup-qa.directenergy.com/webservices/fidelitypaymentswebservice.asmx
Irule using :
when HTTP_REQUEST { if {([HTTP::host] equals "powerup-qa.directenergy.com") and ([HTTP::uri] starts_with "/webservices/") and ([HTTP::path] ends_with ".asmx")} { pool Powerup-QA_pool_http } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } }
- stan_piron
Cumulonimbus
did you assign this irule to HTTP VS only (if assigned to HTTPS VS, it will loop)
The irule seems right (why using HTTP::uri for the start, and HTTP::path for the end... use HTTP::path for both start and end)
if you want to allow uppercase, convert HTTP::path to lower case.
when HTTP_REQUEST { set path [string tolower [HTTP::path]] if {([HTTP::host] equals "powerup-qa.directenergy.com") and ($path starts_with "/webservices/") and ($path ends_with ".asmx")} { pool Powerup-QA_pool_http } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } }Or if you want to manage only host powerup-qa.directenergy.com:
when HTTP_REQUEST { set path [string tolower [HTTP::path]] if {([HTTP::host] equals "powerup-qa.directenergy.com")} { if {($path starts_with "/webservices/") and ($path ends_with ".asmx")} { pool Powerup-QA_pool_http } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } } else { Host header value not managed by the irule } }
