Albert__Tase_70
Jan 11, 2010need somew help setting persistance with irule
Basically they want to match urls and then apply source_address persistance I used contains and the or statement and used
if { ([HTTP::uri] contains "x") or ([HTTP::uri] contains "y") or ([HTTP::uri] contains "z") or ([HTTP::uri] contains "a") or ([HTTP::uri] contains "b") or ([HTTP::uri] contains "c") or ([HTTP::uri] contains "d") or ([HTTP::uri] contains "e"}{
persist source_addr 300
just not seem to presist is the presist command correct?
or should I use startwith instead of contains ?
- The_Bhattman
Hi Albert,
You can certain rewrite you code to the followingwhen HTTP_REQUEST { switch -glob [HTTP::uri] { "*x*" - "*y*" - "*a*" - "*b*" - "*c*" - "*d*" - "*e*" - { persist source_addr 300 } } }
I hope this helps
Bhattman - Albert__Tase_70
How can I set up logging on this rule to verify its firing and setting persistance ?
Al Tase - The_Bhattman
Hi All
Here is a log syntax to see if it's matching or not.when HTTP_REQUEST { switch -glob [HTTP::uri] { "*x*" - "*y*" - "*a*" - "*b*" - "*c*" - "*d*" - "*e*" - { persist source_addr 300 log local0. "Matching" } Default { log local0. "Not matching" } } }
nbeed more help with the logging need to be able to return the source ip when it matches and need to be able to log the url when it matches and dose not match is this possible ?
Thanks - naladar_65658
Altostratus
This might work for you:when HTTP_REQUEST { switch -glob [HTTP::uri] { "*x*" - "*y*" - "*a*" - "*b*" - "*c*" - "*d*" - "*e*" - { persist source_addr 300 log local0. "Matching [IP::client_addr] on [HTTP::uri]" } Default { log local0. "Not matching [HTTP::uri]" } } }
