Patrice_Carbonn
Apr 23, 2013Need help with trunks in VE edition
I can create the trunk just fine and select interface 1.1, 1.2 and 1.3. I then create a VLAN and if i choose tag or untagged, i get the same error saying i need to select an interface
Did anyone ever do this?
i am fairly new to F5 boxes...
thank you in advance
Patrice
- nitass
Employee
BIG-IP Virtual Edition (VE) does not support specific BIG-IP system or VMware features.
These BIG-IP system features are not supported by BIG-IP Virtual Edition (VE).
• Optional BIG-IP system modules, such as:
◦ Link Controller (LC)
• Advanced SSL functions
• Advanced TCP profile settings
• Bridging protocols, such as:
◦ Spanning Tree Protocol (STP)
◦ Rapid Spanning Tree Protocol (RSTP)
◦ Multiple Spanning Tree Protocol (MSTP)
• Link Aggregation Control Protocol (LACP)
• Hard-wired failover
• Federal Information Processing Standards (FIPS) 140-2
These VMware features are not supported by BIG-IP VE:
• VMware Fault Tolerance technology
• vmmemctl memory balloon driver
• Memory snapshots
Manual Chapter: Unsupported BIG-IP Features
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ve-vmware-esx-esxi-11-0-0/5.html - What_Lies_Bene1
Perhaps I'm wrong but shouldn't interface mirroring also be on the list?
Btw nitass, do you know what the situation is with upgrades and downgrades in VE. Are they possible? - nitass
Employee
do you know what the situation is with upgrades and downgrades in VE. Are they possible?i did upgrade and it went well. i never downgraded but i think it could be fine too. - nitass
Employee
Perhaps I'm wrong but shouldn't interface mirroring also be on the list? you are correct. interface mirroring is not supported in virtual edition as well. document has not been updated.
Bug 367862 - LTM v11.0.0 VE interface mirroring support
"Network Interface Port Mirroring is not supported by BIG-IP VE with this release" - What_Lies_Bene1
Thanks as ever Nitass.
