Skuba_85554's avatar
Skuba_85554
Jan 27, 2010
need help with strange java error
hi everyone
background info:
we have a pool of 16 servers but only 3 are currently online. the persisentence method is set to cookie
the problem:
users receive an xml error and when they click on OK they have to log back in to the web site. then everything works ok for a while. this problem appears to be random and experienced rarely
the error (on the client's pc):
network: Connecting https://www.domain.com/webapp/log4j.jar with cookie "BIGipServerdomain_pool=71134474.41300.0000; JSESSIONID=ABC123ABC123ABC123ABCABC123ABC123AB"
java.io.FileNotFoundException: https://www.domain.com/webapp/log4j.jar
please note, there doesn't appear to be any errors on the back end servers which correspond. has anyone seen anything like this before? obviously it looks like the client cannot find the file that they're looking for, but if they're using cookie persistence surely that shouldn't be the case
many thanks
  • hoolio's avatar
    hoolio
    Hi Skuba,
    Do you think this is a persistence issue or some other app layer problem? If you want to eliminate persistence as a possible cause, you could try to reproduce the error with just one pool member enabled.
    Do you see a 404 error on the server for log4j.jar? If not, do you see any access log entry for the request?
    Aaron
  • hi hoolio - thanks for your response
    i'm not sure to be honest. personally, i don't think it's a big ip issue but obviously i've got to investigate just in case. this morning we ran the site on a single server in the pool and still received the same error so i'm pretty sure it's not a persistence issue. having said that, we use standard cookie persistence and i'm wondering if the problem occurs when the cookie session times out?
  • hoolio's avatar
    hoolio
    By definition, session cookies don't time out. The client would stop sending the cookie when the browser is closed and the session cookie in memory is lost.
    If you tested with one pool member and couldn't reproduce the issue, it points to a problem with something other than persistence. Considering it's an application layer error, it's most likely a problem with either the client or the server. Can you try testing direct to the server and eliminate LTM as a possible cause?
    Aaron
  • when we tested this morning on one server, we still received the error, so i don't think it's persistence related as they got the same error on a single server
    the only thing that confuses me (based on what you said about cookie sessions not expiring) is that when they receive the xml error it kicks them out of the site, and they have to log back in. however, at this point we can see that they're been load balanced on to another member. how is this the case if they're using standard cookie persistence and there's been no time delay and they've not closed their browser?!
    thanks again
  • hoolio's avatar
    hoolio
    Sorry, I meant that if you tested with a single member and the issue still occurred, then it's likely not a persistence issue. The only reason I can think of that LTM wouldn't use the same pool member is either the client doesn't present the cookie, the pool member has been marked down, or a different pool has been selected.
    Do you have an iRule enabled on the VIP? If so, what is it doing? Can you use a browser plugin like HttpFox for Firefox or Fiddler for IE to track what's happening prior to/when the error occurs?
    Can you also check the server logs to see what the server is logging in the access and/or error logs? You said you didn't see anything in the logs, but that seems a bit strange of the client is getting a response from the server.
    Aaron
  • Do you have an iRule enabled on the VIP? If so, what is it doing? Can you use a browser plugin like HttpFox for Firefox or Fiddler for IE to track what's happening prior to/when the error occurs?
    there's no irule on this vip, just cookie default persistence and no fallback persistence
    according to our application support team, at the time that the client receives the xml error there is nothing logged on the server
    i'm unsure how to proceed with this one. i've told the business that we could try a different persistence method, but we've been using cookie for years for this particular app so we're obviously reluctant to make any changes
    i'll take a look at the firefox addon
    thanks
  • hoolio
    i have an interesting update for you...
    turns out, this is related to a bug within various java versions which they still haven't managed to fix. apparently, java suddenly stops referencing the big ip cookie and therefore the connection is reset and the client receives another cookie/session id from big ip causing the application to kick them out!
    see this article from sun... http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6799990
    obviously this doesn't appear to be a problem with big ip itself, but we are reasonably confident that by changing the persistence from cookie to source address the problem will go away
    unfortunately, we actually need to use cookie persistence for users coming from certain subnets. therefore, i need to work on an irule that will identify where a user is coming from and then make a decision whether to use cookie or source address persistence
    if you could offer any input/advice it would be much appreciated
    thanks
  • hoolio's avatar
    hoolio
    I'm impressed you were able to track the problem down to such an esoteric bug with Java. Glad you figured it out.
    In addition to the iRule, you could try using cookie insert persistence with a fallback method of source address persistence.
    Aaron
