Need help with SSL termination
So I'm new to hands-on configuring F5. We're using Big-IP 11.3.0 and I'm working in a separate partition. I've created two virtual servers, one with service port 80 and one with 443. Both are standard, source is anything, destination for both servers is the same IP address and points to a working IIS7 box that responds only to port 80. I've also created my node (just the one server right now), and the port 80 works perfectly. My site comes up unencrypted, no problems.
SSL...not so much. I've created a client ssl profile and configured it with a self-signed certificate. On my HTTPS virutal server I've assigned the SSL Profile (Client) to the SSL client profile that I created and the SSL Profile (Server) is blank. However, it just times out. I HTTPS to the destination host IP (which is the same IP used by the non-HTTPS virual server profile) but it just never comes up. I could really use a hand here.
Thanks!
- nitass
Employee
can you post https virtual server and pool configuration?
tmsh list ltm virtual (name)
tmsh list ltm pool (name) - Kevin_Stewart
Employee
Please verify that port translation is NOT disabled on your port 443 virtual server.
