Need help with SSL passthrough while using SNAT and an irule
Yes, for encryption all the way both the BIG-IP and the server needs cert and key. And they can be the same or different, doesn't matter. And yes, if you can get the cert and key from the server you can import it into the BIG-IP, it has the capability to import many different formats.
And also, note that in most cases you don't even need a particular cert and key on the server because the BIG-IP does not by default verify that it is issued by a proper CA and so on. One of the point of handling SSL on the BIG-IP is that you get a centralized certificate management.
