pkhatri_72515
Mar 31, 2010Need help with iRule
Dear Experts,
I need help with iRule:
currently i have following iRule: (which is working fine)
if { ([string tolower [HTTP::uri]] starts_with "/classkb/") or ([string tolower [HTTP::uri]] equals "/classkb") } {
if { not ([matchclass [IP::client_addr] equals $::Classkb_allowed_IPs]) } {
log local0. "Caught [HTTP::uri] from [IP::client_addr]"
HTTP::redirect "http://static.blabla.com/403.htm"
now we need "/classkb/assests" url to be publically accessed, how would i modify this iRule? Need help with adding another if statement.
Thanks,
PK.
- Jason_Keating
Altostratus
How about something along the lines of this.when HTTP_REQUEST { set path [string tolower [HTTP::path]] log local0. $path switch -glob $path { "/classkb/assets"{ } "/classkb*"{ if { not ([matchclass [IP::client_addr] equals $::Classkb_allowed_IPs]) } { log local0. "Caught [HTTP::uri] from [IP::client_addr]" HTTP::redirect "http://static.blabla.com/403.htm" } } } }
Caveat: I've not tested it, and might not be %100 correct syntax - pkhatri_72515
Thanks, I will test and let you know, appreciate your help.
PK. - pkhatri_72515
That worked!! Thanks,
I had to add '*' at the end of '/classkb/assets".
Thanks again for your help.
PK. - pkhatri_72515
well, guess I was wrong, users are reporting that they are able to now access
http://bla.bla.com/classkb - which should be accessed only by those permitted IPs while
http://bla.bla.com/classkb/assets should be accessed by everyone.
PK. - hoolio
