VISHNU1's avatar
VISHNU1
Aug 20, 2021
Need help with DO declaration resource provisioning
Hi I am trying to setup a big-ip vCPM guest using DO declation using postman and below is the script I am using.
Script-1
        "myProvisioningltm": {
            "class": "Provision",
            "ltm": "nominal"
        "Provisioningavr": {
            "avr": "nominal"
        "myProvisioningaasm": {
            "asm": "nominal"
script-2
        "myProvisioning": {
            "ltm": "nominal",
            "avr": "nominal",
            "asm": "nominal"
I get a 200 OK response from the device and after the initial reboot device will open provision ltm module as shown below
                    "currentProvision": {
                        "afm": "none",
                        "am": "none",
                        "apm": "none",
                        "asm": "none",
                        "avr": "none",
                        "dos": "none",
                        "fps": "none",
                        "gtm": "none",
                        "ilx": "none",
                        "lc": "none",
                        "ltm": "nominal",
                        "swg": "none",
                        "urldb": "none",
is their anything wrong with the script?
