william_kimball
Aug 15, 2005Need help with a rule for a test site.
I am trying to create a rule or something similar and need some help. We have 9 servers that are separated into a public pool of three servers (1 test and 2 production) for authentication two private pools (we can call them HTML and .NET with 1 test and 2 production each). We need a test environment that mimics the production environment exactly, if a user clicks a link on a production servers he goes to another production server but if he clicks a link on a test server he is connected to a another test server (when a user logs in on the test public site he is directed only to the test private servers and not the production private servers). We thought about creating new DNS names but then when a site comes into production from test it would require serious modifications, if it is modified at all then it must be put back into testing which means that it would need to be changed again and … I think you can see where this would go. Any help on this would really be appreciated. Thanks in advanced!
- Colin_Walker_12Historic F5 AccountI guess I need a little clarification on the process that a normal request goes through in this environment.
When a user contacts the public VIP, it hits the authentication server. Assuming the user authenticates properly...then what? It's forwarded to one of the web servers by the auth server, or it's re-load balanced to another VIP, or what?
Thanks,
-Colin - william_kimball
Once it authenticates it is forwarded and load balanced to a new VIP depending on what they, the user, chose to connect to. Whatever it is, it is on a VIP for one of the sites on the .NET or HTML servers and there are quite a few. They all have unique IPs and URLs. - william_kimball
any ideas?
