k20's avatar
k20
Dec 04, 2020
Need help to whitelist URI's
I need some help with the iRule. The goal is to allow users to access a limited number of URI's from the Internet but open to all for internal users.
I have created a datagroup that contains the internal subnets called internal_subnets
Here's my iRule
if { [class match [IP::client_addr] equals internal_subnets] }{
   pool app_80_pool
switch -glob [HTTP::host] {
  "app.com" {
       pool app_80_pool
 if {[HTTP::uri] starts_with "/foo/combined.js*" or \
    [HTTP::uri] starts_with "/foo/css/*" or \
    [HTTP::uri] starts_with "/foo/desktopreset" or \
    [HTTP::uri] starts_with "/foo/doc/*" or \
    [HTTP::uri] starts_with "/foo/error404.html" or \
    [HTTP::uri] starts_with "/foo/external/*" or \
    [HTTP::uri] starts_with "/foo/favicon.ico" or \
    [HTTP::uri] starts_with "/foo/home.jsf" or \
    [HTTP::uri] starts_with "/foo/images/*" or \
    [HTTP::uri] starts_with "/foo/include/*" or \
    [HTTP::uri] starts_with "/foo/javax.faces.resource/*" or \
    [HTTP::uri] starts_with "/foo/login.jsf" or \
    [HTTP::uri] starts_with "/foo/resources/*" or \
    [HTTP::uri] starts_with "/foo/scripts/*" or \
    [HTTP::uri] starts_with "/foo/ui/*" or \
    [HTTP::uri] starts_with "/foo/user/*" }{
      pool app_80_pool
else {
       HTTP::redirect "http://app.com/sorry.html"
Nothing works. What did I do wrong here?
Any help would be appreciated.
  • Hi k20,
    Can you try this iRule?
    	if { [class match [IP::client_addr] equals internal_subnets] } {
    		pool app_80_pool
    	else {
    		switch -glob [HTTP::uri] {
    			"/foo/combined.js*" -
    			"/foo/css/*" -
    			"/foo/desktopreset" -
    			"/foo/doc/*" -
    			"/foo/error404.html" -
    			"/foo/external/*" -
    			"/foo/favicon.ico" -
    			"/foo/home.jsf" -
    			"/foo/images/*" -
    			"/foo/include/*" -
    			"/foo/javax.faces.resource/*" -
    			"/foo/login.jsf" -
    			"/foo/resources/*" -
    			"/foo/scripts/*" -
    			"/foo/ui/*" -
    			"/foo/user/*" -
    			"/sorry.html" { pool app_80_pool }
    			default { HTTP::redirect "http://app.com/sorry.html" }
    • k20's avatar
      k20
      Just tried your suggestion. However, when I go to the http://app.com it takes me to the sorry.html which is not what I want.
  • If you want external network clients access to app.com/*
    	if { [class match [IP::client_addr] equals internal_subnets] || [HTTP::host] equals "app.com" } {
    		pool app_80_pool
    	else {
    			"/foo/css/*" -
    			"/foo/doc/*" -
    			"/foo/external/*" -
    			"/foo/home.jsf" -
    			"/foo/images/*" -
    			"/foo/include/*" -
    			"/foo/login.jsf" -
    			"/foo/scripts/*" -
    			"/foo/ui/*" -
    			"/foo/user/*" { pool app_80_pool }
    • k20's avatar
      k20
      OK now external users can get to http://app.com which is great. However, when I type some random URI's other then the ones listed in the iRule such as:
      http://app.com/<some_random_string>
      it doesn't redirect to the sorry.html page. I want it to redirect to the sorry.html page if nothing else matches all of the conditions above (i.e. the internal subnets, the homepage and all URI's in that whitelist).
      • In below rule, you may need more uri for switch list. for example "index.php".
        You should add them in switch func.
        		pool app_80_pool
        	else {
        			"/sorry.html" -
        			"/foo/css/*" -
        			"/foo/doc/*" -
        			"/foo/external/*" -
        			"/foo/home.jsf" -
        			"/foo/images/*" -
        			"/foo/include/*" -
        			"/foo/login.jsf" -
        			"/foo/scripts/*" -
        			"/foo/ui/*" -
  • Above  iRule is correct, You can remove the statement which is creating issue.
    If i will be at you place then can try negative scenario and short irule for fun. You can try to use URI_DB class to add and remove the URI.
    if { !([class match [IP::client_addr] equals internal_subnets]) && ([class match [HTTP::uri] starts_with URI_DB) } {
    else {
    	pool app_80_pool
    Add the all uri in URI_DB
    "/sorry.html"
    "/foo/combined.js*"
    "/foo/css/*"
    "/foo/desktopreset"
    Please tune iRule per requirements.
    • k20's avatar
      k20
      I really appreciate your suggestion. If I understand your iRule correctly, our external users will be having trouble getting to those specific URI's inside the URI_DB, which is not what I want. Let me try to explain my end game here.
      1. There will be no restrictions to access the app for internal users whatsoever. We use source IP addresses to identify them.
      2. External users can only have access to a small subset of the app with some restrictions. They will be allowed to access only the URI's defined under the "switch -glob" inside the iRule (i.e. those /foo/....URI's you see in the original post) and they are also allowed access the main page "app.com"
      3. Finally, if the external users try to access stuff that are not allowed, we want to send them to the sorry.html page.
      This is essentially like if you're inside my house, you can use whatever stuff you want. If you're outside, you can only use my bucket and shovel. If you try to borrow something else, I'm sorry. :)
      I couldn't get the last condition to work.
    • k20's avatar
      k20
      Hey @Samir I think you have a good point. Looks like I misread your iRule. It seems to match my goal. Let me try that and will let you know how it goes. Wish me luck.
    • k20's avatar
      k20
      Just tried it and no luck. If I go to the home page app.com, it redirects me to the sorry.html. By the way, your script is missing the square bracket at the end of the URI_DB. It seems like an easy one. Oh boy, I couldn't get it to work.
