Geoff_31301's avatar
Geoff_31301
Feb 15, 2008
Need Help on Simple iRule Syntax
We need to establish a simple iRule from an external Virtual Server to send to an internal VS...
The question is what is the syntax ? I know this is more of a Tcl question - but stumped!
when CLIENT_ACCEPTED {
*****send to Virtual Server by name***
  • not sure if I understand your question correctly, you may check
    http://devcentral.f5.com/Wiki/default.aspx/iRules.virtual
  • If both virtuals are on the same BIGIP
    you should be able to do so using the syntax virtual your_vs_name
    Be careful it should only be available in 9.4.X
    If you are in a previous version there is no workaround to do such a thing you'll need to upgrade if it's mandatory.
    HTH
    N.
