Robert_47833's avatar
Robert_47833
Jul 04, 2011
need help in forward uri to different pool via specific percentage
I have two pool: cjj1 ,cjj2
1:for uri in data group aaa, send 80% request to cjj1 and 20% to cjj2
2:if one client visit cjj1,all other requests from this client should be sent to cjj1,so I think we should do cookie persisit here
how to achieve this via irule.
we suppose the new cookie is ttttttt
thanks very much
  • hoolio's avatar
    hoolio
    Hi Jucao,
    You can create a string datagroup with the URIs and then use the class command (v10) or the matchclass command (v9) to do the lookup. You can use the rand function to do ratio load balancing between the pools. For requests sent to cjj pool, you can set a cookie and check for that cookie before selecting between the pools. Cookie insert persistence would not work for this scenario as default persistence ensures persistence within a single pool.
    Here are a few related links:
    http://devcentral.f5.com/wiki/default.aspx/iRules/class
    http://devcentral.f5.com/wiki/default.aspx/iRules/matchclass
    http://devcentral.f5.com/wiki/default.aspx/iRules/ratio_load_balancing_using_rand_function.html
    http://devcentral.f5.com/wiki/default.aspx/iRules/http__cookie
    Aaron
  • Hi,dear hoolio
    can u give me an example for this,
    I don't understand this part:Cookie insert persistence would not work for this scenario as default persistence ensures persistence within a single pool.
    I want to insert a new cookie and persist it
    how to achieve this?
  • hoolio's avatar
    hoolio
    Hi Jucao,
    Cookie insert persistence can only be used to persist between members of one pool, not between different pools. Instead you can insert your own cookie and look for that in requests.
    Here's a rough, untested example of what I was thinking of. Note that I've used a session cookie. If the user closes their browser after receiving the cjj1 cookie, they'll get load balanced again and could end up going to the other pool. If you change that to a time-expired cookie to avoid that, over time, more than 20% of the users will get pinned to the cjj1 pool.
        Track whether to set a cookie to force use of the cjj1 pool
       set cjj1_cookie 0
        Check if request already has a cookie indicating
        they should be sent to the cjj1 pool
       if {[HTTP::cookie value cjj1_cookie] == 1}{
           Select the cjj1 pool
          pool cjj1_pool
           Exit this event in this rule
          return
        If we got here, request did not have a pool selector cookie
       if {[class match [HTTP::uri] starts_with cjj1_uri_class]}{
          if { rand() < 0.20 } {
             pool cjj1_pool
             set cjj1_cookie 1
           Default action if a pool was not selected above will be to use the VS default pool
    when HTTP_RESPONSE {
        Check if request was for a cjj1 URI
       if { $cjj1_cookie == 1 }{
           Insert a session cookie in the response
          HTTP::cookie insert cjj1_cookie value 1 path "/"
    Aaron
  • hI,I have worked out,but still need to confirm with u in some details
    Can u have a look at the irule below
    if { $stubhubA_cookie == 1 }{
    HTTP::cookie insert name stubcjjA_cookie value 1 path "/"
    HTTP::cookie expires "stubcjjA_cookie" "25920000" relative
    if { $stubhubB_cookie == 1 }{
    HTTP::cookie insert name stubhubB_cookie value 1 path "/"
    HTTP::cookie expires "stubhubB_cookie" "25920000" relative
    set stubcjjA_cookie 0
    set stubcjjB_cookie 0
    if {[class match $uri starts_with gen3abURLs_SRWD29]} {
    if {[HTTP::cookie value stubcjjA_cookie] == 1}{
    pool SRWD29-G3-BRX
    log local0. "BRX $stubcjjA_cookie PERSIST"
    return
    if {[HTTP::cookie value stubcjjB_cookie] == 1}{
    pool SRWD29-BROWSE
    log local0. "BRX $stubcjjB_cookie PERSIST"
    return
    if { rand() <0.2 } {
    pool SRWD29-G3-BRX
    set stubhubA_cookie 1
    log local0. "BRX stubhubA_cookie $stubcjj_cookie "
    pool SRWD29-BROWSE
    set stubhubB_cookie 1
    log local0. "BRS stubhubB_cookie $stubcjjB_cookie "
    return
    questiones:
    1:when u mention session cookie ,it means when I close the broswer,the cookie will expire?
    how to set cookie as session cookie or permanent cookie
    2:in the HTTP_RESPONSE event,it will affect all the http response? if some traffic didn't have the cookie,what will irule do?
  • hoolio's avatar
    hoolio
    If you set an expire time of something other than 0 on the cookie it should be saved by the client on the filesystem and sent on each request until it expires. If you don't set an expire time or set it to 0, then the client should store it in memory and not send it after the browser is closed.
    If no cookie needs to be set in HTTP_RESPONSE the example I posted won't do anything.
    Aaron
  • hoolio's avatar
    hoolio
    Aaron
  • Hi,Hoolio
    you give me great help on this,I respect u
    have a good day
