Need help for redirction of append URI
I have difficulties in redirection- I want to do a redirection abc.com to abc.com/act on both http and https
when HTTP_REQUEST { if {[string tolower [HTTP::host]] equals"abc.com" or [string tolower [HTTP::host]] equals"abc.com"}{
switch -glob [HTTP::path] {
"/*" {HTTP::respond 301 Location " https://abc.com/act[HTTP::uri]"}
Or
when HTTP_REQUEST { if {[string tolower [HTTP::host]] equals"abc.com"}{ if {[HTTP::uri] starts_with "/act" }{ HTTP::uri /act[HTTP::uri] log "hit uri act"} } }
Both rules are not working Kindly give an advice
Thank you
- stan_piron
Cumulonimbus
you can try this code:
when HTTP_REQUEST { if {[string tolower [HTTP::host]] equals "abc.com" && !([HTTP::path] starts_with "/act" )}{ HTTP::respond 301 Location "/act[HTTP::uri]" log local0. "[HTTP::uri] redirected to /act[HTTP::uri]" return } } - mohana_322852
switch -glob [HTTP::path] { "/" {HTTP::respond 301 Location " https://abc.com/act[HTTP::uri]"}
I would like to withdraw my request. It is working with above iRule. Thank you - stan_piron
Cumulonimbus
Why do you compare twice HTTP::host with abc.com?
The irule may not work without space between
andequals"abc.com"Do you only want to redirect / or all URI not starting with /act ?
If redirection is on the same service than the first request (user request https://abc.com/ and you want to redirect to https://abc.com/act/), you can redirect to relative URI instead of absolute:
HTTP::respond 301 Location "/act[HTTP::uri]"a switch command in this irule is useless and a if may be used...
