Need help decoding iRule
Hi guys, I inherited the system from ex sys-admin and I found an itneresting iRule which I would like to know the effect for :
The irule is as follows :
when HTTP_REQUEST { set second [string first "/" [HTTP::uri] 1] incr second if { $second > 0 } { set third [string first "/" [HTTP::uri] $second] if { $third >= 0 } { set uniqueuri [string range [HTTP::uri] 0 $third] persist uie $uniqueuri 28800 } } }
Any tips?
- Theo_12742
Cirrus
It appears to be a rule designed to create a persistence record based on values from the URI.
I've added syntax formatting and comments to the code below, roughly explaining the logic.
when HTTP_REQUEST { Search the URI for a slash (skipping the first character) and record it's index value into the value second. If it doesn't find another slash, the value of second will be -1 set second [string first "/" [HTTP::uri] 1] Add 1 to second incr second This if is true unless the search above did not find another slash, at which point the iRule exists without setting a persistence record if { $second > 0 } { Repeat above looking for a third slash. set third [string first "/" [HTTP::uri] $second] Again skips the creation of a persistence record unless a third slash was found if { $third >= 0 } { Create a universal persistence record based on the URI, but only the portion before the third slash set uniqueuri [string range [HTTP::uri] 0 $third] persist uie $uniqueuri 28800 } } }
