nimda_205570
Mar 11, 2016Need help create regex check host url
Hi guys I need help create irule to check url request from client. The url is like = www.webiste.com/Key=kddkdyryltkAction=01,04,20&Value=100,100,100 Requrement: irule should check if inside the url detect Action value cannot duplicated "cannot have value number 01 two or three times"
Thanks, NS
- stan_piron
Cumulonimbus
you can try an irule like that:
when HTTP_REQUEST { set actionlist [split [URI::query [HTTP::uri] Action] ","] if {[llength $actionlist] && [llength $actionlist] ne [llength [lsort -unique $actionlist]]} { There is a duplicate entry... } } }
