Albert__Tase_70
Dec 21, 2006need help converting this rule from 4 to 9.2.4
if (http_host contains "demo.nature.com" or http_host contains "deutsche.nature.com" or http_host contains "mailart.nature.com" or http_host contains "fastart.nature.com") {
use pool nature
else if (http_header("User-Agent") contains "Google" or http_header("User-Agent") contains "google" or http_header("User-Agent") contains "Ask" or http_header("User-Agent") contains "msn") {
use pool spider_pool
else if (http_host contains "isn-online.org") {
if (http_uri == "/" or http_uri == "/index.html") {
redirect to "http://www.nature.com/isn"
else {
use pool Java
else if (http_host contains "www.palgrave-journals.com") {
redirect to "http://www.palgrave-journals.com/pal"
else if (http_uri == "/mysiteaccount") {
redirect to "http://www.palgrave-journals.com/nams/svc/mysiteaccount"
else if (http_uri starts_with "/cgi-bin" or http_uri starts_with "/services/link.taf" or http_uri == "/login/login.taf") {
use pool nature
else if (http_uri starts_with "/registration/Modify_registration.taf" or http_uri starts_with "/registration/modify_registration.taf" or http_uri starts_with "/registration/index.taf") {
redirect to "http://www.palgrave-journals.com/myaccount"
else if (http_uri starts_with "/registration/register.taf" or http_uri == "/pal/register/redirect.taf") {
redirect to "http://www.palgrave-journals.com/register"
else if (http_uri starts_with "/site_registration/site_login.taf") {
else if (http_uri == "/site_registration/") {
else if (http_uri starts_with "/site_registration/site_register.taf") {
redirect to "http://www.palgrave-journals.com/nams/svc/siteregister"
else if (http_uri starts_with "/offer/" or http_uri starts_with "/cgi-taf/links.taf") {
redirect to "http://www.palgrave-journals.com/empty.txt"
else if (http_uri starts_with "/cgi-taf/button_link.taf") {
redirect to "http://www.palgrave-journals.com/"
else if (http_uri starts_with "/cgi-taf/subscribe_link.taf") {
redirect to "http://www.palgrave-journals.com/subscribe"
else if (http_uri starts_with "/dynasearch" or http_uri starts_with "/Dynasearch" or http_uri starts_with "/DynaSearch") {
redirect to "http://www.palgrave-journals.com/common/access/replaced.vm"
else {
use pool palgrave-foxtrot
else if (http_uri starts_with "/cgi-bin" or http_uri starts_with "/services/link.taf" or http_uri starts_with "/ebd/cpd/" or http_uri starts_with "/doifinder/10.1057" or http_uri starts_with "/doifinder/10.1080" or http_uri == "/login/login.taf") {
use pool nature
else if (http_host contains "www.naturereprints.com") {
redirect to "http://www.nature.com/reprints/index.html"
redirect to "http://www.nature.com/myaccount"
else if (http_uri starts_with "/registration/register.taf") {
redirect to "http://www.nature.com/register"
redirect to "http://www.nature.com/mysiteaccount"
else if (http_uri == "/site_registration") {
redirect to "http://www.nature.com/siteregister"
redirect to "http://www.nature.com/empty.txt"
redirect to "http://www.nature.com/index.html"
redirect to "https://secure.nature.com/subscribe/nature"
redirect to "http://www.nature.com/common/access/replaced.vm"
else if (http_uri starts_with "/cgi-taf/Ea2.taf") {
redirect to "http://www.nature.com/nature-events/search-events/index.html"
else if (http_uri starts_with "/login/password_help.taf") {
redirect to "http://www.nature.com/nams/svc/lostpassword"
else if (http_uri starts_with "/help/advertising") {
redirect to "http://npg.nature.com/media/nature/index.html"
else if (http_host contains "www.emboj.org") {
redirect to "http://www.nature.com/emboj/"
else if (http_host contains "emboreports.npgjournals.com") {
redirect to "http://www.nature.com/embor/"
else if (http_host contains "embojournals.npgjournals.com") {
else if (http_host contains "www.npgjournals.com") {
redirect to "http://www.nature.com/embojournal/"
else if (http_host contains "www.journalofmedicalmarketing.com") {
redirect to "http://www.palgrave-journals.com/jmm"
else if (http_host contains "www.damjournal.com") {
redirect to "http://www.palgrave-journals.com/dam"
else if (http_uri starts_with "/press/") {
redirect to "http://press.nature.com"
else if (http_uri starts_with "/public/") {
redirect to "http://nurture.nature.com/search"
else if (http_host == "www.nature.com" and http_uri starts_with "/rss/" and http_uri ends_with "/index.html") {
redirect to "http://www.nature.com/webfeeds/index.html"
else if (http_host contains "www.nature.com" and http_uri contains "/rss/") {
else {
use pool Java
- Wow, that's a long iRule...
Here's a start of the first part to get you going. You should be able to figure out how to convert the rest from this...
I stored some common values (host, user-agent, and uri) in local lower case variables to avoid multiple comparisons in some places just to account for case sensitivity.when HTTP_REQUEST { set host [string tolower [HTTP::host]] set ua [string tolower [HTTP::header "User-Agent"]] set uri [HTTP::uri] if { ($host contains "demo.nature.com") || ($host contains "deutsche.nature.com") || ($host contains "mailart.nature.com") || ($host contains "fastart.nature.com") } { pool nature } elseif { ($ua contains "google") || ($ua contains "ask") || ($ua contains "msn") } { pool spider_pool } elseif { $host contains "isn-online.org" } { if { ($uri equals "/") || ($uri equals "/index.html" } { HTTP::redirect "http://www.nature.com/isn" } else { pool Java } } elseif { $host contains "www.palgrave-journals.com" } { if { ($uri equals "/") || ($uri equals "/index.html" } { HTTP::redirect "http://www.palgrave-journals.com/pal" } elseif { $uri equals "/mysiteaccount" } { HTTP::redirect "http://www.palgrave-journals.com/nams/svc/mysiteaccount" } elseif { ($uri starts_with "/cgi-bin") || ($uri starts_with "/services/link.taf") || ($uri equals "/login/login.taf") } { use pool nature } ... } ... }
Good luck and let us know if you get stuck...
-Joe - Albert__Tase_70
hey joe at the bootn of your text with all the } do I continue after that or do I insert before that ? - Continue where the ...'s are (that's where I left off in your original code). The last brace is the closing brace for the HTTP_REQUEST event. If you want to include code past that point you'll have to enclose it in a different event.
-Joe
