Network_Team_11's avatar
Network_Team_11
May 30, 2013
Need Help: APM - Assigning Static ACLs by username
Hi all,
I am trying to design a dynamic access policy to support vendor remote access without using dynamic ACLs. The reason for this is that I want to configure the ACLs in the Edge Gateway and not RADIUS. I opened a support case and was told that I could write an iRule which assigns a static ACL using ACCESS::acl eval.
So I tried it out with the following:
when ACCESS_POLICY_AGENT_EVENT {
variable varUser
set varUser [ ACCESS::session data get "session.logon.last.username" ]
ACCESS::acl eval $varUser <-----this line errors with the following message: line 4: [command is not valid in current event context (ACCESS_POLICY_AGENT_EVENT)] [ACCESS::acl eval $varUser]
Does this error mean that ACCESS::acl isn't compatible with the ACCESS_POLICY_AGENT_EVENT?
What would make this work?
The way I imagine this working is:
- when we set up a new vendor for remote support, we create a static ACL with the name matching the vendor's username
- the vendor enters their login info
- the access policy calls this iRule with an iRule Event action
- the username is placed inside of varUser
- and finally, the ACL with the same name as the username is applied to the connection
Am I doing this all wrong?
I appreciate any input on this. Thanks.
  • The ACCESS:acl command is only valid under the ACCESS_ACL_ALLOWED and ACCESS_ACL_DENIED events. These are the last events that fire in an access policy evaluation, and generally the only ACCESS events that fire after policy evaluation (per request after authentication).
  • Thank you for pointing that out, Kevin. I've adjusted my script accordingly, but am having a difficult time getting the iRule to launch in my access policy. Either the script isn't being activated, or it is being evaluated as having no effect on the session. So I have a question regarding access policies.
    When I add an iRule action to the access policy in the VPE, it has a single field called ID. What is that asking for? I thought it required the name of the iRule I created under Local Traffic | iRules, but that didn't seem to be doing anything. Then I though maybe it was asking for the actual TCL code, but still nothing. I have read all the documentation I can find and nothing seems to answer this. Could you please shed some light on the iRule Event action? Thanks!
  • Hamish's avatar
    Hamish
    The ID is a flag passed to the iRule to indicate what you want... YOur iRUle has the event ACCESS_POLICY_AGENT_EVENT in it, and you access that value from the VPE object by \[ACCESS::policy agent_id\]
    e.g. From devcentral wiki (https://devcentral.f5.com/wiki/iRules.ACCESS_POLICY_AGENT_EVENT.ashx)
                if { [ACCESS::policy agent_id] eq "lastLogon" } {
                             our limit in seconds
                            set 2weeks 1209600
                             diff in 100 nanosecond increments between MS time attribute (year 1601) and start of epoch
                            set offset 11644473600000
                            set adtime "[ACCESS::session data get session.ad.last.attr.lastLogon]"
                             convert adtime to milliseconds
                            set millisecs [expr {$adtime / 10000}]
                             subtract offset
                            set lastlogintime [expr {$millisecs - $offset}]
                             convert to seconds because milliseconds for 'now' were negative (maybe vmware issue)
                            set secs [expr {$lastlogintime / 1000}]
                            set now [clock seconds]
                             finally calculate the difference
                            set diff [expr {$now - $secs}]
                            log local0. "lastLogon: $diff seconds from current time"
                            if { $diff > $2weeks } {
                                        ACCESS::session data set session.custom.lastLogonWithin2Weeks 0
                                        ACCESS::session data set session.custom.lastLogonWithin2Weeks 1
    H
  • To elaborate on Hamish's excellent comments, the iRule processor is continually listening for events throughout a connection. APM's iRules event agent is the channel it uses to connect to the iRule processor, via the ACCESS_POLICY_AGENT_EVENT event, and the agent's ID is the point of entry. So you could easily have different APM iRules event agents firing at different points in the policy evaluation. Here's another example:
       switch [ACCESS::policy agent_id] {
          "BEFORELDAP" { ...do something... }
          "AFTERLDAP" { ...do something... }
          "BEFORESSO" { ...do something... }
    Also, at different points in policy evaluation you may have access to session values that didn't exist until a specific agent fired (LDAP query, On-Demand Cert Auth, etc.), or you may need to insert an event before an agent to condition the variables for that agent. Lot's of possibilities.
  • OK thanks guys. This is starting to make sense to me. If ACCESS::acl eval is only usable from the ACCESS_ACL_ACCEPT or ACCESS_ACL_DENIED events, how do I get my access policy to trigger it if the VPE object only generates the ACCESS_POLICY_AGENT_ EVENT? My revised iRule code is as follows:
    when ACCESS_ACL_ALLOWED {
    variable varUser
    set varUser [ACCESS::session data get "session.logon.last.username"]
    Secondly, does $varUser need to contain the partition of where the ACL is located, or just the name? Thanks!
  • 1. All of the other ACCESS events are triggered automatically when the access policy evaluates. Only the ACCESS_POLICY_AGENT_EVENT event requires a manual trigger. Further, ACCESS_ACL_ALLOWED fires on every request after policy evaluation. You can kind of think of it like an HTTP_REQUEST event with guaranteed access to APM session values.
    2. While you may not in some circumstances, it's best practice to include the partition information if not /Common.
  • Thanks again for that explanation, Kevin. You have helped me understand a lot more than when I started this thread. I think I found a different way of accomplishing what I want. I inserted a Variable Assign object in the policy and set it to ACLs with a value of expr {"/Common/[mcget {session.logon.last.username}]"} and it works! Now I can leave my policy alone and just create vendor acounts in AD along with static ALCs that match the vendor's username in the Edge Gateway. Provisioning vendor remote access should be a breeze now.
    • tacobell911_122's avatar
      tacobell911_122
      Would you mind showing a screen shot of the config you have setup please.
