Arthur_7109
Jul 02, 2010MySQL errors and database maintenance
Hi there,
We are regularly seeing this ASM database error message:
Database error in ASM:
Invalid SQL: DELETE FROM LRN_NEGSIG_SIGNATURES WHERE sig_id='200002273' AND account_id='25'
mysql error: Deadlock found when trying to get lock; try restarting transaction
mysql error number: 1213
Date: Tuesday 29th 2010f June 2010 01:23:28 PM
Script: /dms/policy/lrn_negsigs.php
Referer: https://bigip/dms/policy/lrn_negsigs.php
Any idea how bad this is, and how to fix it?
Also, does the ASM MySQL database require any maintenance?
Are there any guidelines, tips or best practices for ASM MySQL database management and maintenance?
Thanks,
Arthur
- Ido_Breger_3805Historic F5 AccountHi,
This needs to be looked by F5 Support, I suggest to open a support case.
The ASM database doesn't require maintenance or specific management. - Arthur_7109
OK thanks I'l open a case then.
Also I will try this:
MySQL recovery and optimization (CR121832)
This release includes the following tools:
* recover_db.pl - This tool allows MySQL to recover when it becomes corrupted.
* optimize_db.pl - This tool allows you to run the MySQL optimize command on Application Security Manager tables.
To run these tools, open the command line interface utility and run the following commands: /usr/share/ts/bin/recover_db.pl or /usr/share/ts/bin/optimize_db.pl.
