sosabsd_111766's avatar
sosabsd_111766
Feb 07, 2009
my LTM memory issue
Hi
last day i check my LTM 6800 it consume 3GB out of 4GB total memory, can you explain why, and how to prevent it.
i restart the LTM and now i can see on LCD memory is about 200MB to 300MB.
BR
sosa
  • If this is not in line with your normal trends and your traffic patterns haven't changed, it's possible you're facing a memory leak. Unfortunately, we aren't equipped here to assist with those problems, you'll need to reach out to the product support team: https://websupport.f5.com Click here
  • Hi
    thanks for reply, on LCD screen i also see 4d DOS Attack message,it might be possible due to DOS attack on LTM, if yes , then where i can see these DOS attack logs (var/log/ltm or some where else.
    BR
    sosa
  • Hi
    it was issue of ltm memory leak , which fixed after software upgrade from 9.1.2 to 9.3.1 HF8
    BR
    sosa
