My F5 Virtual edition license not able to activate
We purchased few Virtual LTM license from F5. But myself not able to activate the license in my F5 Virtual machine(BIGIP-11.6.0.0.0.401.ALL-scsi).kindly help
Myself getting below error
Licensing Error: Error 51133, F5 registration key is not compatible with the detected platform - This platform, "Z99V", cannot be activated with this registration key "NTKSHLW-ZUBXVMU".
- stan_piron
Cumulonimbus
The key you provided is not a registration key but an add-on key.
registration key format is:
XXXXX-XXXXX-XXXXX-XXXXX-XXXXXXPlease do not post on any forum your key.. if you cannot register, someone else can use it and enable another VM and lock it on the F5 registration server.
Stanislas
- IMABBAS_90_3240
Even m getting the same error when registering with the key provided. any solution for this.
- Samir_Jha_52506
Noctilucent
Looks like your system is not compatible with F5 image. Check with F5 Support.
- dragonflymr
What type of Hypervisor are you using? Is that VMware? If so I never saw platform Z99V when using VMware based VM.
Piotr
