muhammed's avatar
muhammed
Dec 18, 2019
mutiple URL redirect(irule) not working
I currently have an issue as i had below mentioned irule configured and recently i have upgraded my box and after that my irule is not working.
my requirement is i have one VIP which have two applications running. and i want to redirect each application url with another FQDN.
under VIP: x.x.x.240
{ if request got for abc.com it should redirect to abc.com/login/yyy/ddd
and
if request got for def.com it should redirect to def.com/login/zzzz/mmm }
this is my requirement.
and what i have facing with below rule is its only responding to my second rule 1st rule not working, even if i was also.
 if {([HTTP::host] eq "eem-int.abc.com") and ([HTTP::uri] eq "/")} {
  HTTP::redirect "https://eem-int.abc.com/en-GB/app/EEM_dashboards/eem__home"
 if {([HTTP::host] eq "da-int.abc.com") and ([HTTP::uri] eq "/")} {
  HTTP::redirect "https://da-int.abc.com/en-GB/app/DA_dashboards/da_home"
kindly suggest.
  • Hello, what version are you currently using?
    If v14 or later, is it not a case to apply this new feature?
     https://clouddocs.f5.com/api/irules/HTTP__has_responded.html
    Let me know.
    Regards.
