Multiple Request using single TCP Connection simultaneously
Hi everyone!
We need to have a single TCP Connection used by multiple request. Clients are behind the F5 LTM and the Server will accept only single TCP Connection. Different clients (lets say 2 clients) needs to connect to the server simultaneously.
Is there a way to do this? I believe that Oneconnect is not we are looking for since it will use the same tcp connection AFTER the first session
Thank you everyone. I hope someone can lend some help.
- JG
Cumulonimbus
What do you mean by "Clients are behind the F5 LTM"?
- F5_Jeff
Cirrus
These clients are also servers that initiate connections to F5.
- JG
Cumulonimbus
Not clear what business requirement would need this, and I don't think one connection can handle two requests at exactly the same time.
It seems you need to serialise client requests to a single connection. If we assume it uses the HTTP protocol, with OneConnect enabled, you can set the maximum number of connections to 1 on the pool member, and also enable request queueing.
