Dexter_126558
Aug 22, 2013Multi Vlans configuration on F5 Viprion
I currently have a F5 Viprion LTM configured for my App servers.
Users are currently accessing the App server through the below,
User -> Firewall -> F5 LTM(Virtual Server IP) -> Server physical IP
Would it be possible to configure for other vlans(Infra/Web/DB) using the same Viprion as well? The gateways for each Vlan are pointing to the firewall.
- Michael_Yates
Hi Dexter,
Sure you can do that with multiple VLAN's. These should help you get started.
Configuring Routes and Route Domains
