Zeeshan_Ahmad_1's avatar
Zeeshan_Ahmad_1
Apr 14, 2015
Multi domain SSO and login does not work after the Inactivity Timeout
I have a APM policy configured for MultiDomain SSO, it works fine with the first login but if inactive Timeout occurs then once user try to login it always redirects to logout page. May I need to do some more configuration or its a known issue
  • Gianrico_D_Ang1's avatar
    Gianrico_D_Ang1
    Historic F5 Account
    You might be running into BUG 498926
    There is not fix for that yet.
    You can try a workaround.
    Work-around is modify the href of the 'Session Expired Message' so that it redirects to www.site.com In the text customization for the 'Session Expired Message', replace [SESSION_RESTART_URL] with session variable %{session.server.network.name}
    thanks
    gianrico
