MS NLB for Exchange 2010 and importing Exchange ssl certs to bigip v11.4.1
Im in a situation where I am working with someone to export the IIS SSL certs from their CAS servers. Im using digicerts link to do this Digicert export pfx cert but Im questioning if I can install the pfx cert directly to the F5 or is there something I need to do to manipulate it?
Im looking and using GoogleFu but apparently it is not strong today. Im looking for a link that would help me with this item?
Im using version 11.4.1 HF3 on the LTMs.
- uni_87886
You can import the pfx file directly. Select import type PKCS12 in File Management/SSL Certificate List/Import. You can also (my preference) convert them to PEM format first from the bash shell on the F5 with something like (from my imperfect memory):
openssl pkcs12 -in my.pfx -nodesthen just paste the certificate and key parts into the appropriate text boxes in the GUI.
- fubarSUSHI
Altocumulus
Awesome. That is what I was hoping for... I can use the pfx directly on the F5. I wanted to make sure but I had no way of confirming. I believe the older versions dont allow you to use .pfx? - uni_87886
You might be right there. I only discovered when someone else had done so here.
- uni
Altocumulus
- fubarSUSHI
Altocumulus
Altocumulus
