Mattews's avatar
Mattews
Icon for Cirrus rankCirrus
Jan 23, 2019
Monitoring Thresholds
Hi experts,
i use an i5800 F5 model, which are the recommended limits that should not be exceeded concerning CPU usage, Memory, Throughput, Total connections and TPS ?
I must do a report and i need to know these values.
Thanks in advance.
  • For CPU/Memory/Throughput/Total Connections, it depends on the hardware platform and how you are utilizing it (single or multi tenant / application resource consumption). You can set a threshold that is 50-70% of the limit of the platform and start considering an upgrade once the threshold is hit. TPS depends on your licensing and platform.
    If you are using the device in Active-Active setting, you would have to utilize a threshold lower than 50%.
