mrosedale_13329
Sep 09, 2013Monitoring SNMP issue
Hello,
I'm working on monitoring my BIG-IP 10.1.0 Build 3341.0 Final. I'm running the following snmp command which should return a hex-string of that I can convert to an IP address.
snmpwalk -m ALL -v 2c -c public lb.com .1.3.6.1.4.1.3375.2.2.10.1.2.1.3
However, there a couple of Virtual Servers that return STRING: "F*>..." rather than Hex-String: Any ideas what is going on here?
Thanks mjr
- dirtycache
What IP address are you trying to retrieve, and what do you want to do with it? - mrosedale_13329
It is the virtual server's IP Address. Should return something like the following. F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."xxx_http" = Hex-STRING: 40... Instead I'm getting the following only on a small handful of virtual servers F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."xxx_http" = STRING: "F*>(" I'm using this with my monitoring software for reporting and monitoring. - hoolio
Here's a sample of the response from an 11.x VE:
snmpwalk -m ALL -v 2c -c public localhost .1.3.6.1.4.1.3375.2.2.10.1.2.1.3 F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."/Common/vea_http_vs" = Hex-STRING: 0A 00 29 69What are the VS names which return the garbled characters?
Aaron
- mrosedale_13329
F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."cap_http" = STRING: "F*>v" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."nwp_http" = STRING: "F*>C" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."psp_http" = STRING: "F*>*" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."cap_https" = STRING: "F*>v" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."cncp_http" = STRING: "F*>r" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."nwp_https" = STRING: "F*>C" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."psp_https" = STRING: "F*>*" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."cncp_https" = STRING: "F*>r" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."wowpp_http" = STRING: "F*>7" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."watson_http" = STRING: "F*>(" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."wowpp_https" = STRING: "F*>7" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."watson_https" = STRING: "F*>(" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."wowpeuusp_http" = STRING: "F*>8" F5-BIGIP-LOCAL-MIB::ltmVirtualServAddr."wowpeuusp_https" = STRING: "F*>8"- mrosedale_13329
So here are the VS names that are returning garbage.
