hc_andy_35682
Feb 16, 2010Monitoring current traffic per VIP
Hi All,
Is there a way to monitor the traffic/bandwidth utilization per VIP.
I'm using BIG -IP LTM 6900 version 10.0.1. From the GUI, I can access virtual server statistics but they don't show the current bits and packets but only give you a total count. They do however show you the current connection count but I'm more interested in knowing the bandwidth utilization of the VIP.
Screen shot attached.
Thanks.
Andy
- hc_andy_35682
I think it's a global setting only but not 100% sure. - hc_andy_35682
Sorry I know this is a dumb question, but does the little "m" in the graph indicate milli??
So if I've got 250m connections/sec then that equates to 15 connections/min???
Thanks.
Andy - JRahm
Admin
That's correct. - hc_andy_35682
Hi Jason,
I've got the cacti template for the F5 working great! Will there be any future plans to add monitoring for the nodes so we can find out the traffic, connection rate and current connections per node too?
Thanks.
Andy - JRahm
Admin
I'm always looking for suggestions to expand the template. The nodes are probably pretty easy, pool members will be more challenging. - Hamish
Cirrocumulus
I have some perl code that does this... Pulling the data is easy... (Although my code uses iControl, not SNMP).
I think what's needed most is a way to have the cacti server poll the F5 every X seconds (e.g. 86400, 1 day) and automatically discover the VS's, Pools and poolmembers, nodes etc and automatically start gathering stats (And stop) based on pool membership, etc...
H - JRahm
Admin
That would be incredibly useful. Does cacti have an API for actions like this? I haven't looked that deeply. Without, would be some serious DB work to make it happen. - Hamish
Cirrocumulus
I'd have to look. I suspect it doesn't and would require direct manipulation of the cacti database... - hc_andy_35682
I'm getting strange results for the number of current connections to our dns virtuals. We have two dns virtuals and the first one shows no current connections where as the second virtual always display this weird graph shape for the same time period.
Any ideas?? - Hamish
Cirrocumulus
Is your cacti server overloaded? The polling on cacti isn't very intelligent, and breaks easily under load. If your poll times go much above 30 seconds then you're heading into territory that will result in dropouts (Manifested usually as missing data).
BTW.. That looks like a lot of connections... I'd drop the idle connection timeout for udp/53 down to about 10 seconds... (Especially if they're not doing recursive queries, the first timeout for DNS is 5 seconds so even going down to 10 should ideally be too long to cause any problems).
