Kevin_Nail
Oct 20, 2006Monitor Help with SSL certs
Hi
I don't know if anyone has run across this problem or not but I have an application that I'm trying to monitor that is throwing a client certificate accept screen back to the big-ip and my https content monitor is failing because it doesn't know how to get wround this problem.
Is there anyway to get around this? or fix it?
Many thanks.
- hoolio
Hello,
This isn't rule related so the question should be directed to support. However, in the HTTPS monitor configuration options, you can specify a client SSL certificate that the BIG-IP will present to the nodes.
Here is a note from the online help:
Client Certificate
Specifies a fully-qualified path for a client certificate that the monitor sends to the target SSL server.
If you want more detail, I imagine the LTM config guide has it.
Thanks,
Aaron - Kevin_Nail
Many thanks!
