Chamiho
Feb 11, 2010Monitor Functions on BIGIP-Link Controller
Dear All
Hello Everybody, i am newbie on F5 product. And glad to see you all in here.
I had a problem on configuring BIGIP-LC on v9.4.8
BIGIP was put on one-arm and listening the traffic coming from Two Cisco Router and every router have connected to different outgoing line, The two cisco router are using "GLBP ". and i used cisco's virtual-gateway-address for my bigip default gateway.
And i'm configured health monitor(gateway_icmp) on "Links" monitors and check the two Links available or not. After the configured , i had try to ping both links, it's ok . But on the monitor section, there were only one link was "ON", the other can't.
And i try to create the pool of both links and used the gateway_icmp monitor to check the links. Both of the links is ok!
So what should i do to correct the problem on "Links" monitor?
Thank you for all.
Bryant.
