Lobak_187587
Jun 13, 2016monitor for mariadb cluster
Mariadb 10 is using galera for multi-master setup Before this I'm using haproxy installed in front of nginx like this article http://galeracluster.com/documentation-webpages/haproxy.html
How do I do same with F5 Big-IP v11?
Yes, just see below my lab configuration
ltm virtual vs_mariadb { destination 192.168.1.10:mysql ip-protocol tcp mask 255.255.255.255 persist { source_addr { default yes } } pool pool_smtp profiles { fastL4 { } } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled vs-index 4 } ltm pool pool_mariadb { members { 192.168.1.1:mysql { address 192.168.1.1 session monitor-enabled state down } 192.168.1.2:mysql { address 192.168.1.2 session monitor-enabled state down } 192.168.1.3:mysql { address 192.168.1.3 session monitor-enabled state down } } monitor tcp_half_open }You can also change the default tcp monitor by a custom mysql monitor :
ltm monitor mysql monitor_mariadb { count 0 debug no defaults-from mysql destination *:* interval 30 recv none send none time-until-up 0 timeout 91 username haproxy }
