Jake_105797
Apr 27, 2012Monitor citrix through web interface servers
We load balance two citrix web interface servers and use a standard http health monitor on them. We need to figure out a monitor that will:
1. Connect to each web interface server
2. Accept the auto redirect from the server to an https:// citrix page
3. Log in to the page
4. Check the delivered page for a receive string.
5. If failure - mark that one web server as down (the one it connected to in step 1)
Is there a way to script this in an iRule? Other ideas? We're running 10.2.0 code.
Thank you!
- Hamish
Cirrocumulus
Use an external monitor. I usually write it in perl, or bash. Then you have access to things like curl...
H - Jake_105797
I was thinking perl could be used but I'm a bit rusty on it. I'm trying to search up some examples. Do you have any examples that would show any piece of this process? - hwidjaja_37598
Altostratus
Have you seen this: http://www.f5.com/pdf/deployment-guides/f5-citrix-xenapp-dg.pdf - Techgeeeg
Hi Jake,
Which version of TMOS are you using currently???? The iApp feature of the new release gives you the synthetic monitors/Advanced Monitors which will accept a username and password from you and based on that it logs in to analysic which servers is actually serving the client and which one not. I beleive it will help you.
Regards, - Jake_105797
I'm running 10.2.0 code. I did find the deployment guide over the weekend and it looks like I need to be at 10.2.1 to get the right template to do this. Also looks like we need to configure a DNS server for the f5 to query so we can enter the domain / uri into the template.
