Raj_57800
Oct 05, 2010Monitor Certificate
Hi All,
I wanted to monitor the devcie certificate properties. I need a alert to be created before the certificate expires.
Is there any log created to indicate that the certificate is going to expire ? If yes, can anyone provide me a sample message. Thaks
Raj
- George_Watkins_Historic F5 AccountHi Raj,
In the past I have used Opsview (Nagios) to monitor certificate expirations. There is a built-in module called check_http that will do the trick. The syntax for the command looks like this: check_http -H $HOSTADDRESS$ -C 14.
-George
