Gazzu's avatar
Gazzu
Jun 30, 2017
Monitor at pool keeps going up and down (flapping) continuously.
Hi All,
Need urgent help, I have pasted the logs below wherein monitor keeps going up and down (flapping) continuously. I am not able to find that, is it related to F5's configuration issue or server end issue?
mcpd[5768]: 01070638:5: Pool /ap-$$$$-132/p-.net-10100 member /ap-$$$$-132/node:10100 monitor status down. [ /ap-$$$$-132/CSS-keep-alive: down; last error: /ap-$$$$-132/CSS-keep-alive: Response Code: 200 (OK); Unable to connect; No successful responses received before deadline.; Response Code: 404 (Not Found) @2017/06/30 09:08:06. ] [ was up for 0hr:0min:16sec ]
  • If you need urgent help, please call F5 support.
    We can help you in devcentral, but devcentral is not a replacement for F5 support.
    If you want to analyse the problem yourself, we can in devcentral provide guidance to you. In this case, can you please provide the pool and monitor configuration?
