sena_291474's avatar
sena_291474
Dec 26, 2017
milli-voltage (<voltage>) is too low ,Power supply failure </voltage>
Hi, I am getting the following message on the display.
milli-voltage () is too low ,Power supply failure
But I can see the following outputs Chassis Power Supply Status Index Status Current 1 up AC 2 up AC
Chassis Fan Status Index Status Low Limit(rpm) Fan Speed(rpm) 1 up 1000 12200 2 up 1000 12000 3 up 1000 12200 4 up 1000 12000
Accroiding to F5 document,it says Description:This message occurs when one of the following conditions is met: External power to the PSU is lost. Input power readings are out of the recommended range.
What is the solution?Any clue?? Thank You
