Maximum Connections Statistics
Hi all, I need to understand better why MaxConnStats on VIP side is different from MaxConnStats on its Pool side and why there are more connections on "delivery9" node (RoundRobin method).
VS is standard-flat without OneC configuration.
Could someone help me?
Thanks in advance and Brgds
- nitass
Employee
i think it may be because they are on different side (client-side and server-side).
[root@ve11a:Active:In Sync] config grep -A 7 ltmVirtualServStatClientMaxConns\ OBJECT-TYPE /usr/share/snmp/mibs/F5-BIGIP-LOCAL-MIB.txt ltmVirtualServStatClientMaxConns OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "The maximum connections from client-side to the specified virtual server." ::= { ltmVirtualServStatEntry 10 } [root@ve11a:Active:In Sync] config grep -A 7 ltmPoolMemberStatServerMaxConns\ OBJECT-TYPE /usr/share/snmp/mibs/F5-BIGIP-LOCAL-MIB.txt ltmPoolMemberStatServerMaxConns OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "The maximum connections from server-side to the specified pool member." ::= { ltmPoolMemberStatEntry 9 }why there are more connections on "delivery9" node (RoundRobin method).
is delivery9's hardware same as others?
- Jo_31162
Many thanks nitass. But should not be equal? 20.8K IN and 20.8K OUT instead of 4.8K OUT?
- nitass
Employee
is client-side and server-side equally fast? is it possible that responsiveness on each side is not equal?
- Jo_31162
I think yes but the truoble is that I don't have lost traffic on each side.
All works fine but I don't understand this difference.
Any suggestion nitass?
