  • As such there is no limitation of adding member in pool. you can add as much you can.
    • sidd76's avatar
      sidd76
      That is what I thought. Thanks for confirming.
  • carlile's avatar
    carlile
    The default value of 0 specifies that there is no limit on the number of connections allowed per second. The optimal value to specify for a pool member is between 300 and 5000 connections.
    ____________________________________________________
    mcdvoice login
  • I think below command can be used
    sys license detail | grep ltm_lb_pool_member_limit
