Simon_Jones_112
Sep 26, 2006Matching a GUID in a querystring?
Hi all,
Anyone tell me why this won't work? Is it possible to use \w's in an IRule?
set querystring URI::query
if { $querystring contains "productid" } {
Match the GUID in product and redirect it to the URL:
set productid [regexp -all -inline -indices {\w{8}-\w{4}-\w{4}-\w{4}-\w{12}} [HTTP::uri]]
Log to syslog-ng
log local0. "Found product: $productid"
Simon
- hoolio
If \w isn't working, you might try expanding it to [A-Za-z0-9]. I'm not sure which regex library is used, but this might be a valid workaround.
Edit: actually \w matches _ as well, so you could use [A-Za-z0-9_] as an equivalent to \w.
Aaron - Simon_Jones_112
Thanks, almost there with this.
S
