Joseph_Goyette_'s avatar
Joseph_Goyette_
Mar 16, 2005
matchclass and syntax errors
I've got a simle iRule below based on the example in the Writing iRules section of the LTM guide.
In a nutshell, I am attempting to direct requests to specific urls based on the client's ip address. I've copied the matchclass syntax directly from the manual yet I keep getting a syntax error:
Line 10: [parse error: PARSE syntax 264 {syntax error in expression "[IP::remote_addr] eq matchclass Esc-External-Networks ": variable references require preceding $}] [{[IP::remote_addr] eq matchclass Esc-External-Networks }]
Substituting the generic "aol" data group name produces the same error.
 when HTTP_REQUEST
    if {[HTTP::uri] starts_with "/all/"} {
       use pool ALL-POOL
    elseif {[HTTP::uri] starts_with "/CustomerA/"} {
       use pool POOL-A
    elseif {[HTTP::uri] starts_with "/CustomerB/"} {
       if {[IP::remote_addr] eq matchclass Esc-External-Networks } {
          use pool POOL-B
          HTTP::redirect "http://www.escription.com/"
What am I missing here ?
Thanks !
Joe
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    I believe the syntax in your matchclass usage is wrong. Try this instead:
     if {[matchclass [IP::remote_addr] eq $::Esc-External-Networks] } {
        use pool POOL-B
  • What if you wanted to not specify the pool, but deny everything outside of the matchclass, how would you do a "does not equal". Something like this:
     when CLIENT_ACCEPTED {
        if {[matchclass [IP::remote_addr] !eq $::allowed-group] } {
          discard
    It doesn't like the !eq section. Any ideas how to do this?
    unRuleY_95363
    Historic F5 Account
    Try this:
        if {not [matchclass [IP::remote_addr] eq $::allowed-group] } {
           discard
