JeffRW's avatar
JeffRW
Aug 03, 2016
Marking false positive for Credit Card number (Data Guard)
Our ASM is flagging a value (d132c*****a6e5) that's actually part of a name of a Java script on various URLs.
Is there a way to exclude this value, or mark this value as a false positive regardless of the URL?
Thx
  • Hello,
    Its about Data Guard, isn't?
    If so, I try to set an exception pattern or defining an url list exception to bypass it.
    Regards
  • Navigate to Security ›› Application Security : Data Guard and change the settings there. Select the policy and disable the options or add the ignore list.
    Hope it helps.
    -Jinshu
