pawel_jakacki_7
Feb 07, 2012Manual synchronization process using Operator level user
Hello,
is there any possibility in F5's LTM to make manual synchronization process from user account with Operator level priviledges?
Regards Pawel
- nitass
Employee
there is request for enhancement which is tracked as ID 273333. anyway, it is not available in current release.
ID 273333 - AuthZ: User-definable roles (Formerly CR 51850) - pawel_jakacki_7
thank you for helpful answer. I have one more question. Is there possible to start manual synchronization process by a user with administrator priviledges which operates on non common partition? Does in that solution only non common partition content will be synchronized? - nitass
Employee
i never tested; anyway, i do not think configsync is per partition. - pawel_jakacki_7
I've checked this, you're right, only administrator is able to start synchronization process.
thanks for your help
Regards
Pawel
