Management IP discrepancy LTM
I have a query about an LTM I am looking at. There seems to be a discrepancy with the mgt IP and I don't know if this is expected.
If I look in the GUI under | system | platform | it shows the IP I would expect, let's say 10.0.10.1. It also shows the same IP in tmsh when I run the command: "tmsh list /sys management-ip" But when I do an ifconfig, the device shows a different IP address, it shows the default IP it ships with (192.168.1.245) I only noticed this because I was working with SNMP and doing a tcpdump for troubleshooting and I noticed it was sending traps and sourcing them from the default IP: 192.168.1.245) Something doesn't seem right here.
Any info appreciated.
