Major difference between BIG-IP GTM and LTM Physical and Virtual Appliance
Hi Guys, would some one be able to help me with some design and solution question question my client is asking for Please
Question - Should we go for GTM/LTM Appliance Physical or Virtual edition
I need some expert advise on Pros and Cons PLEASER
- nathe
Cirrocumulus
- Techgeeeg
Hi Monaro,
If its a GTM+LTM combo then I will recommend to go with Physical Appliance.
Regards,
- hwidjaja_37598
Altostratus
Physical Appliance would be better if it handles heavily SSL transaction or does acceleration.
In a complex environment, you can also design to dedicate SSL processing to physical appliance and assign VE to do particular task of load balancing.
Btw, there are a few other factors to consider in choosing between physical or virtual.
- monaro888_12150
Hi Guy, Thanks so much for the feedback, really appreciate it.
Quesiton for hwidjaja - Would you kindly elaborate more on (other factors to consider in choosing between physical or virtual) and Provide some more details on it. PLS
- hwidjaja_37598
Altostratus
I would recommend to read the pdf from Nathan and to consult with F5.
Some considerations are like cost efficiency, manageability, flexibility, sizing, security, etc.
- Kevin_Stewart
Employee
I think the biggest difference between physical and virtual is what's often called "speeds and feeds" - the amount and throughput capacity of the appliance. While the newer VE licensing can blur that line a bit, the software is identical, so you're basically missing the hardware-specific acceleration features of the physical box (SSL, caching, compression, etc.). One other consideration is the box itself. The platform is ICSA-certified, so you can put a BIG-IP in your DMZ and treat it like a firewall (with or without AFM). If you run it in a VE, there's an additional hypervisor layer above the BIG-IP that is now dependent on the security of the virtualization vendor and the commodity hardware you're running it on. Considering that a GTM is usually located closer to the edge of the network than other load balancing services, it may make more sense to go physical.
- monaro888_12150
Thanks Guys! Its been a great help.
