Wil_Schultz_101
Mar 19, 2007Maintenance page?
So in the v4 version of the BigIP you used to be able to create virt, rule, pool and also a maintenance page if the given pool in the rule was down. This doesn't seem to be an option on the v9.2.4 so far as I can tell so I am hoping that someone can tell me the best way to implement this...
I'm using irules that look similar to the following:
switch -glob [string tolower [HTTP::uri]] {
"/uri1/*" -
"/uri2/*" -
"/uri3/*" {
pool poola
"/uri4/*" -
"/uri5/*" -
"/uri6/*" {
pool poolb
"/uri7/*" -
"/uri8/*" -
"/uri9/*" {
pool poolc
default {
pool defaultpool
}So, if pool a were down I'd like the request to go to "http://maintenance.my.com" but the other pools to serve normally. I've found this in another post but wondering if this is the best way:
when LB_FAILED {
switch [LB::server pool] {
poola -
poolb -
poolc {
HTTP::redirect http://maintenance.my.com
} 1 Reply
- Colin_Walker_12Historic F5 AccountIf what you're looking to do is to test a pool's status before sending traffic there, you can do so by adding a little logic like this:
switch -glob [string tolower [HTTP::uri]] { "/uri1/*" - "/uri2/*" - "/uri3/*" { if {[active_members poola] > 0} { pool poola } else { pool fallback_poola } } "/uri4/*" - "/uri5/*" - "/uri6/*" { if {[active_members poolb] > 0} { pool poolb } else { pool fallback_poolb } } "/uri7/*" - "/uri8/*" - "/uri9/*" { if {[active_members poolc] > 0} { pool poolc } else { pool fallback_poolc } } default { pool defaultpool } }
